#159819 - 07/05/2003 16:22 Playing "root" causes re-boot.
SE_Sport_Driver
I'm upto 18,900 tracks on my player and this just started happening after adding the last 300 or so...
While playing 1 song on repeat, I had this happen:
When I press the down button 3 times on the player, the player thinks (hourglass), pauses then reboots. Repeatable. This is also with Repeat and Shuffle (Newest Additions) enabled.
The I played a playlist that has 200 or so tracks in it. That played fine. Then I pressed the down button 3 times again. Rebooted itself.
But, ever since playing the root via emplode, all is fine.
Could this be because of my playlist/database size?
I havn't been able to get a serial log yet, but I was curious if any of you thought maybe this could be due to playlist size?
#159820 - 07/05/2003 16:29 Re: Playing "root" causes re-boot. [Re: SE_Sport_Driver]
Or maybe it's something odd in one of the 300 tracks you just added. Can you make a temporary playlist of just those 300 tracks and try to play that?
#159821 - 07/05/2003 19:29 Re: Playing "root" causes re-boot. [Re: tfabris]
genixia
Along that line of reasoning - you could also try an oldest or most-played shuffle of the complete playlist. This should eliminate the playlist size as being the cause.
